Une nouvelle version Alpha de Windows Blue a été diffusée sur la toile, cette fois-ci en 64 bit : WINDOWS BLUE BULID 9369 X64
Voici quelques captures d'écran ==> https://goput.it/f1r6ijq Si vous désirez tester cette version, ne pas l'utiliser comme système principal sur votre PC.
A tester uniquement soit en virtuel soit en Dual Boot !!!!!!!!!!
Les nouveautés :
Anglais :
Spoiler : :
Metro Applications
New Alarms application.
New Calculator application
New Movie Moments application.
New Sound Recorder application.
Skydrive replaced File Manager application.
References to Windows Defender application.
Updated Settings application.
Automatic updates.
User Interface
Bigger/Smaller tiles for start screen.
Slide up from start to view all apps screen.
Slide to Shutdown feature.
Color slider for theme.
Picture frame for lock screen.
Start screen sync.
New search animation.
Multiple snapped applications on wide screen.
Now apps can be snapped too on screen resolutions below 1366 x 768.
Half-Half option for metro applications.
Metro applications on multiple monitors.
Thinner borders for some desktop applications.
No transparent window on minimizing/closing.
Support for touchpad gestures without any additional driver.
Charmbars is now semi-transparent.
Start screen groupnaming can be done without zooming out.
Switching apps now lets you decide to put on left or right snap.
Button on bottom of start page to enter app list.
Searchbar on the app list page.
New animation for opening apps.
Save on skydrive by default option.
Internet Explorer
Synced tabs feature.
Download list feature on metro version.
Userstring added "like Gecko" which Firefox uses.
History wipe on desktop like the one in metro version.
References to WebGL support.
References to Spdy-protocol support.
Metro styled F12 Developer Tools
Kernel
Less ram usage.
References to Minkernel.
References to BaseFS.
References to 3G/4G tethering.
References to barcode scanning.
Support for wireless displays (In Settings app)
Support for touchpad gestures (In Settings app)
(Resilient File System) Key features of the new file system (ReFS)
Metadata integrity with checksums.
Integrity streams providing optional user data integrity.
Allocate on write transactional model for robust disk updates (also known as copy on write).
Large volume, file and directory sizes.
Storage pooling and virtualization makes file system creation and management easy.
Data striping for performance (bandwidth can be managed) and redundancy for fault tolerance.
Disk scrubbing for protection against latent disk errors
Resiliency to corruptions with "salvage" for maximum volume availability in all cases.
Shared storage pools across machines for additional failure tolerance and load balancing.
User Interface
Internet Explorer
Kernel
Spoiler : :
Applications de métro
Nouvelle application Alarmes.
nouvelle application Calculatrice
nouveau film demande des Moments.
Nouvelle application Sound Recorder.
Skydrive remplacé demande du gestionnaire de fichiers.
Les références à l'application Windows Defender.
Mise à jour application Paramètres.
mises à jour automatiques.
Interface utilisateur
tuiles plus / de moins pour l'écran de démarrage.
Glissez vers le haut à partir du début pour voir tout l'écran apps.
glisser à fonction d'arrêt.
curseur de couleur pour thème.
cadre d'image pour l'écran de verrouillage.
Démarrer la synchronisation de l'écran.
Nouvelle recherche animation.
multiples applications s'arrachent sur grand écran.
Maintenant applications peuvent être cassés aussi sur les résolutions d'écran ci-dessous 1366 x 768.
demi-Half option pour les applications de métro.
applications Metro sur plusieurs moniteurs.
frontières diluant pour des applications de bureau.
Aucune fenêtre transparente sur la minimisation / fermeture.
Soutien aux gestes du touchpad sans aucun pilote supplémentaire.
Charmbars est maintenant semi-transparent.
Début groupnaming de l'écran peut se faire sans un zoom arrière.
applications de commutation permet désormais vous décidez de mettre en pression à gauche ou à droite.
bouton au bas de la page d'accueil pour accéder à la liste app.
Barre de Recherches sur la page de la liste des app.
nouvelle animation pour l'ouverture des applications.
Économisez sur SkyDrive par option par défaut.
Internet Explorer
Synced fonction des onglets.
Télécharger fonctionnalité de liste sur la version métro.
UserString ajouté "like Gecko" qui utilise Firefox.
Histoire essuyer sur le bureau comme celui de la version de métro.
références à l'appui WebGL.
références à l'appui spdy-protocole.
Metro style F12 Outils pour développeurs
Kernel
Moins utilisation de la RAM.
références à Minkernel.
références à BaseFS.
références à 3G/4G tethering.
références à balayage de codes à barres.
en charge des affichages sans fil (dans Paramètres app)
soutien pour les gestes du touchpad (dans Paramètres app)
(Resilient File System) Principales caractéristiques du nouveau système de fichiers (ReFS)
intégrité des métadonnées avec des sommes de contrôle.
flux Integrity fournissent l'intégrité des données de l'utilisateur en option.
Allouer le modèle transactionnel écrire les mises à jour de disques robustes (aussi connu comme copie sur écriture).
Grand volume, de fichiers et tailles de répertoire.
stockage mutualisation et de virtualisation rend la création de système de fichiers et une gestion facile.
l'entrelacement des données pour des performances (bande passante peut être géré) et la redondance pour la tolérance aux pannes.
nettoyage de disque pour la protection contre les erreurs de disque latentes
résilience de corruptions avec "sauvetage" pour la disponibilité de volume maximum dans tous les cas.
pools de stockage partagés entre les machines pour la tolérance de panne supplémentaire et l'équilibrage de charge.
Internet Explorer
Kernel
MD5 : bbe552053f426d18495e0f3ca61d919b
Téléchargement : Google
