Page 1 sur 8
(RESOLU)ecran bleu mes que au redémarrage du pc
Posté : sam. 26 janv. 2013 22:45
par neos666
voila j ai un Ecran bleu mes que quant je redemarre le pc j ai utiliser une des logiciel que j ai trouver pour un rapport, j ai besoin d aider quart pour les mis a jours ses genial quant on doit le redémarré
donc pour résumer l ordinateur fonction bien sauf quant je veut faire un redémarrage
voici le rapport de
Spoiler : :
System Information (local)
computer name: GAMMES-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 4247416832 total
VM: 2147352576, free: 1960820736
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 26/01/2013 21:30:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012613-22152-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8006BC0620, 0xFFFFFA8006BC0900, 0xFFFFF800035E6460)
Error: CRITICAL_OBJECT_TERMINATION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Mon 21/01/2013 11:58:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-17846-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8005FC8AA0, 0xFFFFFA8005FC8D80, 0xFFFFF800035C7460)
On Mon 21/01/2013 11:44:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-19515-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80065F5060, 0xFFFFFA80065F5340, 0xFFFFF800035E4460)
On Mon 21/01/2013 07:59:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-35178-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8005F08B30, 0xFFFFFA8005F08E10, 0xFFFFF800035CD460)
On Sat 19/01/2013 12:38:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012013-19437-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800519DB30, 0xFFFFFA800519DE10, 0xFFFFF80003584460)
On Sat 19/01/2013 03:14:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-19578-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80066BA8E0, 0xFFFFFA80066BABC0, 0xFFFFF800035E3460)
On Sat 19/01/2013 02:16:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-20498-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800691A780, 0xFFFFFA800691AA60, 0xFFFFF8000359A460)
On Sat 19/01/2013 02:01:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-30279-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80066DFB30, 0xFFFFFA80066DFE10, 0xFFFFF800029E2460)
On Sat 19/01/2013 01:53:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-31278-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800672E8B0, 0xFFFFFA800672EB90, 0xFFFFF80003589460)
On Fri 18/01/2013 01:09:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-24538-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8006396060, 0xFFFFFA8006396340, 0xFFFFF80003580460)
On Fri 18/01/2013 01:02:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-36519-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800670F370, 0xFFFFFA800670F650, 0xFFFFF80003582460)
On Mon 14/01/2013 20:06:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011413-24960-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800616C640, 0xFFFFFA800616C920, 0xFFFFF80003586460)
On Thu 10/01/2013 21:29:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011013-26083-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80067CF740, 0xFFFFFA80067CFA20, 0xFFFFF80003586460)
On Thu 10/01/2013 14:34:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011013-25771-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80064D4060, 0xFFFFFA80064D4340, 0xFFFFF800035D4460)
Conclusion
19 crash dumps have been found and analyzed. Only 15 are included in this report. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
ps j'espère ne pas avoir trot mis sinon désolé d avance :$
Re: ecran bleu mes que au redémarrage du pc
Posté : dim. 27 janv. 2013 08:50
par palerider
• Lance le (si tu es sous Windows Vista ou Windows 7, fais le par un clic-droit --> Exécuter en temps qu'administrateur)
• Vérifie si tu trouves une icône "UAC" en haut à droite de ZHPDiag : si c'est le cas, clique dessus.
•Clique sur l’icône représentant un tournevis, sur la fenêtre qui se déroule, clique sur Tous
• Clique sur l'icône représentant une loupe (« Lancer le diagnostic »)
• Enregistre le rapport sur ton Bureau à l'aide de l'icône représentant une disquette
  • Le rapport étant trop long pour être posté sur le forum, il faut l' héberger.
Là je suis grippé je ne regarderai peut-être que demain si ça va mieux
Posté : dim. 27 janv. 2013 12:12
par neos666
ok je fait sa et j ai oublier de préciser que en mode sans échec il démarre tre bien et redemarre tré bien et merci beaucoup
Posté : dim. 27 janv. 2013 12:23
par neos666
http://up2sha.re/file?f=kwD3uO4s3KZq" onclick="window.open(this.href);return false;
Posté : mar. 29 janv. 2013 08:45
par neos666
il y a plus personne pour répondre a mon problème le lien plus haut et le résulta du rapport merci d avance
Posté : mar. 29 janv. 2013 08:55
par palerider
neos666 a écrit :il y a plus personne pour répondre a mon problème le lien plus haut et le résulta du rapport merci d avance
Ne t’inquiète pas ça vient , je suis malade donc moins actif sur le forum, je regarde ton rapport aujourd'hui et je te dis quoi :)
Posté : mar. 29 janv. 2013 08:59
par palerider
--\\ Logged in mode
~ Computer Name: GAMMES-PC
~ User Name: Administrateur
~ All Users Names: UpdatusUser, HomeGroupUser$, Administrateur,
~ Unselected Option: O45,O61,O62,O65,O66,O80,O82,O89
Logged in as Administrator
Tu n'as pas cliqué sur tous comme je te l'ai demandé ! Des fois après avoir cliqué sur l'icone uac il faut refaire la manip (cliquer sur le tournevis et cliquer sur tous !
Important pendant le temps de la procédure ne télécharge pas et n'installe pas de logiciels à l’exception de ceux que je t'indiquerai !
Posté : mar. 29 janv. 2013 23:37
par neos666
ben pourtant si pourtant je vais recommencer
Posté : mar. 29 janv. 2013 23:48
par neos666
voila j espert que ce cous si j ai bien fait les chose
http://up2sha.re/file?f=Yjxig7FFTvWZ" onclick="window.open(this.href);return false; voici le raport et merci de ta reponse
Posté : mer. 30 janv. 2013 08:36
par palerider
Tu es infecté par des Adwares, PUP, toolbars, tu as des cracs et keygens que je te conseille de mettre à la corbeille !
Nous allons utiliser un premier outil de nettoyage :
AdwCleaner - Recherche :
  • Télécharge AdwCleaner ( d'Xplode ) sur ton bureau.
  • Lance le, clique sur [Recherche] puis patiente le temps du scan.
  • Une fois le scan fini, un rapport s'ouvrira. Poste moi son contenu dans ta prochaine réponse.
  • Note : Le rapport est également sauvegardé sous C:\AdwCleaner[R1].txt
Donc j'attends ton rapport pour continuer :)
