donc pour résumer l ordinateur fonction bien sauf quant je veut faire un redémarrage
voici le rapport de
Spoiler : :
System Information (local)
computer name: GAMMES-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 4247416832 total
VM: 2147352576, free: 1960820736
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 26/01/2013 21:30:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012613-22152-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8006BC0620, 0xFFFFFA8006BC0900, 0xFFFFF800035E6460)
Error: CRITICAL_OBJECT_TERMINATION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Mon 21/01/2013 11:58:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-17846-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8005FC8AA0, 0xFFFFFA8005FC8D80, 0xFFFFF800035C7460)
On Mon 21/01/2013 11:44:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-19515-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80065F5060, 0xFFFFFA80065F5340, 0xFFFFF800035E4460)
On Mon 21/01/2013 07:59:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012113-35178-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8005F08B30, 0xFFFFFA8005F08E10, 0xFFFFF800035CD460)
On Sat 19/01/2013 12:38:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012013-19437-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800519DB30, 0xFFFFFA800519DE10, 0xFFFFF80003584460)
On Sat 19/01/2013 03:14:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-19578-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80066BA8E0, 0xFFFFFA80066BABC0, 0xFFFFF800035E3460)
On Sat 19/01/2013 02:16:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-20498-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800691A780, 0xFFFFFA800691AA60, 0xFFFFF8000359A460)
On Sat 19/01/2013 02:01:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-30279-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80066DFB30, 0xFFFFFA80066DFE10, 0xFFFFF800029E2460)
On Sat 19/01/2013 01:53:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011913-31278-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800672E8B0, 0xFFFFFA800672EB90, 0xFFFFF80003589460)
On Fri 18/01/2013 01:09:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-24538-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8006396060, 0xFFFFFA8006396340, 0xFFFFF80003580460)
On Fri 18/01/2013 01:02:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-36519-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800670F370, 0xFFFFFA800670F650, 0xFFFFF80003582460)
On Mon 14/01/2013 20:06:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011413-24960-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800616C640, 0xFFFFFA800616C920, 0xFFFFF80003586460)
On Thu 10/01/2013 21:29:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011013-26083-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80067CF740, 0xFFFFFA80067CFA20, 0xFFFFF80003586460)
On Thu 10/01/2013 14:34:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011013-25771-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80064D4060, 0xFFFFFA80064D4340, 0xFFFFF800035D4460)
Conclusion
19 crash dumps have been found and analyzed. Only 15 are included in this report. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Crash Dump Analysis
Conclusion
ps j'espère ne pas avoir trot mis sinon désolé d avance
