Windows 7 xdark™ deluxe v4.5 x64 rg - codename: State of ind
roroXP
Message par roroXP »
Windows 7 xDark? Deluxe v4.5 x64 RG-Codename: State Of Independence | 4.84 GB
xDark? has been build using only WAIK without removing any components or disabling any important services at all. The xDark? core consists of more than 500 .dll files modified to integrate a new and different look into Windows 7.
In the Start Menu you will find many tools to Edit, Tweak, Customize, Fix or Search anything you need in the System, the xDark? Power Tools compile everything you need to Customize your OS to the limits making it more personal than ever and even faster, giving you the option to edit system files and applications with just a single right click and supporting the full modification or creation of Windows 7 Styles with the Integration of 7 Style Builder.
If you are an experienced user xDark? 4.0 Series lets you create your own switchless installers or execute applications with parameters / silent switches in live mode using the context menu, you will also find many other options like customizing the icons appearance of the system and applications individually, changing the attributes options of files, renaming or copying the name of multiple files at once, saving the desktop icons position to restore them whenever you want... and many more..
# Enjoy the power of xDark? v4.5 RG
- Original Core by: skat666
- Upgraded, tewaked & tested by: mr. Citr3x
- Installation Requirements:
* 1 gigahertz (GHz) or faster 64-bit
* 2 gigabyte (GB) RAM
* 25 GB available hard disk space
* Internet Connection
* DVD / USB HDD-Stick with more than 5,2 GB Space
* DirectX 9 graphics device with WDDM 1.0 or higher driver
- Additional Installation Requirements:
* Internet access (fees may apply)
* Depending on resolution, video playback may require additional memory and advanced graphics hardware
* For some Windows Media Center functionality a TV tuner and additional hardware may be required
* Windows Touch and Tablet PCs require specific hardware
* HomeGroup requires a network and PCs running Windows 7
* DVD/CD authoring requires a compatible optical drive
* BitLocker requires Trusted Platform Module (TPM) 1.2
* BitLocker To Go requires a USB flash drive
- Unattended Install Procedure:
* Select Time and Currency Format
* Select Keyboard Settings
* Select Hard Disk To Install
* Create User Account
- Unattended User Profile:
* Time Zone: (UTC-08:00) Pacific Time (US & Canada)
* UI Language: en-US
- Language:
* English
- Integrated Updates:
Code:
* Service Pack 1 RTM
* Microsoft Windows Updates Lib okt. 011 ( 251 Updates)
* Microsoft? Windows? Malicious Software Removal Tool (1)
* Microsoft .NET Framework 4 Client Profile (2)
HotFixID=KB2160841
HotFixID=KB2446708
* Microsoft .NET Framework 4 Extended (1)
HotFixID=KB2416472
- Status:
* 30 Days Trial
- xDark? ISO Info:
* Uncompressed Size: 5,2 GB
* Windows 7 Ultimate
* 7 xDark Deluxe v4.5 64-Bit RG.iso
* CRC32: 851AD505
* MD5: 34AA1C98EAC4348F631238E4FEC3BDF7
* SHA-1: 9C8368B1AE543D0ED75B550194EE91E112A5527A
Install Notes:
DVD-LD or an external disk Space needed
INTERNET CONNECTION AT THE 1ST BOOT TIME NEEDED!
Read the Install How To
Install the Windows on a clean HDD
Activate the Windows with the Lastest Loader or an Original Ultimate Key
tophechris94
Re: Windows 7 xdark™ deluxe v4.5 x64 rg - codename: State of
Message par tophechris94 »
traduction : xDark? a été construit en utilisant uniquement WAIK sans enlever tous les composants ou la désactivation des services importants à tous. Le xDark? noyau se compose de plus de 500 fichiers. dll modifié pour intégrer un regard nouveau et différent dans Windows 7.
Dans le menu Démarrer, vous trouverez de nombreux outils pour modifier, Tweak, Personnaliser, Fix ou Recherche chose dont vous avez besoin dans le système, le xDark? Power Tools compiler tout ce qu'il faut pour personnaliser votre OS pour les limites rendant plus personnelle que jamais et encore plus vite, vous donnant la possibilité d'éditer les fichiers système et des applications avec un simple clic droit et en soutenant la modification ou la création complète de Windows 7 Styles Avec l'intégration de 7 Style Builder.
Si vous êtes un utilisateur expérimenté xDark? 4.0 Series vous permet de créer vos propres installateurs switchless ou exécuter des applications avec des paramètres / interrupteurs silencieux en mode direct en utilisant le menu contextuel, vous trouverez également de nombreuses autres options comme la personnalisation de l'apparence des icônes du système et les applications individuellement, en changeant les options des attributs de fichiers , renommer ou copier le nom de plusieurs fichiers à la fois, sauvegarder la position des icônes de bureau pour les restaurer quand vous voulez ... et beaucoup plus ..
# Profitez de la puissance des xDark? v4.5 RG
- Core originale: skat666
- Mise à jour, tewaked & testé par: mr. Citr3x
- Exigences d'installation:
* 1 gigahertz (GHz) ou plus rapide 64-bit
* 2 gigaoctets (Go) de RAM
* 25 Go d'espace disque disponible
* Connexion Internet
* DVD / disque dur USB-Stick avec plus de 5,2 Go d'espace
* DirectX 9 avec pilote WDDM périphérique graphique 1.0 ou supérieur
- Exigences supplémentaires pour l'installation:
* Accès Internet (des frais peuvent s'appliquer)
* Selon la résolution, la lecture vidéo peut nécessiter davantage de mémoire et de matériel graphique avancé
* Pour certaines fonctionnalités Windows Media Center, un tuner TV et du matériel supplémentaire peut être requis
* Windows Touch et Tablet PC nécessitent un matériel spécifique
* Résidentiel nécessite un réseau et des ordinateurs fonctionnant sous Windows 7
* DVD / CD nécessite un lecteur optique compatible
BitLocker nécessite * Trusted Platform Module (TPM) 1.2
* BitLocker To Go nécessite un lecteur flash USB
- Procédure d'installation sans surveillance:
* Sélectionner le format horaire et la monnaie
* Sélectionnez Réglages du clavier
* Sélectionnez disque dur pour installer
* Créer un compte utilisateur
- Profil de l'utilisateur sans surveillance:
* Time Zone: (UTC-08: 00) Heure du Pacifique (Etats-Unis & Canada)
* UI Langue: fr-FR
- Langue:
* Anglais
- Mises à jour intégrée:
Code:
* Microsoft Windows Updates Lib oct. 011 (251 Mises à jour)
* Microsoft. NET Framework Client Profile 4 (2)
HotFixID = KB2160841
HotFixID = KB2446708
* Microsoft. NET Framework 4 étendue (1)
HotFixID = KB2416472
- Situation:
* 30 jours d'essai
- XDark? ISO Info:
* Taille non compressée: 5,2 Go
* 7 Deluxe v4.5 xDark 64-Bit RG.iso
* CRC32: 851AD505
Notes d'installation:
DVD-DL ou un espace disque externe nécessaire
Connexion Internet à la 1ère fois BOOT NÉCESSAIRE!
Lire l'installer Comment
Installez Windows sur un disque dur propre
Activer Windows avec les derniers Loader ou une clé originale Ultime
