Voici un petit récapitulatif des erreurs Windows (Blue screen) qu'on peu rencontrer, il s'agit des erreurs sous WIndows XP, je ne sais pas si elles sont valables pour Vista.
Pour seven je n'ai jamais eu un seul écran bleu...
ERREUR Référencée
"Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL"
"Stop 0x000000A0 INTERNAL_POWER_ERROR"
"Stop 0x000000A5 ACPI_BIOS_ERROR"
"Stop 0x00000019 BAD_POOL_HEADER"
"Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED"
"Stop 0x00000024 NTFS_FILE_SYSTEM"
"Stop C000028 {Défaillance d'un fichier du registre}"
"Stop 0x0000002E DATA_BUS_ERROR"
"Stop 0x0000003F ou Stop 0x3F ou NO_MORE_SYSTEM_PTES"
"Stop 0x00000044 Multiple_IRP_Complete_Requests"
"Stop 0x0000004E PFN_LIST_CORRUPT"
"Stop 0x00000005 INVALID_PROCESS_ATTACH_ATTEMPT"
"Stop 0x00000050 PAGE_FAULT_NONPAGED_AREA"
"Stop 0x00000050 PAGE_FAULT_IN_NONPAGED_AREA"
"Stop 0x00000024 PAGE_FAULT_IN_NONPAGED_AREA"
"Stop 0x0000006B PROCESS1_INITIALIZATION_FAILED"
"Stop 0x00000074 BAD_SYSTEM_CONFIG_INFO"
"Stop 0x00000077 KERNEL_STACK_INPAGE_ERROR"
"Stop 0x00000079 MISMATCHED_HAL"
"Stop 0x0000007A KERNEL_DATA_INPAGE_ERROR"
"Stop 0x0000007B INACCESSIBLE_BOOT_DEVICE"
"Stop 0x0000007E SYSTEM_THREAD_EXCEPTION_NOT_HANDLED"
"Stop: 0x0000007E usbhub.sys"
"Stop 0x0000007F UNEXPECTED_KERNEL_MODE_TRAP"
"Stop 0x0000008E KERNEL_MODE_EXCEPTION_NOT_HANDLED"
"Stop1 0x0000009C MACHINE_CHECK_EXCEPTION"
"Stop 0x0000009F DRIVER_POWER_STATE_FAILURE"
"Stop 0x000000BE ATTEMPTED_WRITE_TO_READONLY_MEMORY"
"Stop 0x000000C2 ou Stop 0xC2 ou BAD_POOL_CALLER"
"Stop 0x000000CE DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS"
"Stop 0x000000D1 ou Stop 0xD1 ou DRIVER_IRQL_NOT_LESS_OU_EQUAL"
"Stop 0x000000EA ou Stop 0xEA ou THREAD_STUCK_IN_DEVICE_DRIVER"
"Stop 0x000000ED ou Stop 0xED ou UNMOUNTABLE_BOOT_VOLUME"
"Stop 0x000000F2"
"Stop 0x000000F4 CRITICAL_OBJECT_TERMINATION"
"Stop 0xC0000135"
"Stop 0xC0000218"
"Stop 0xC000021A STATUS_SYSTEM_PROCESS_TERMINATED"
"Stop C000021a
"Stop 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH"
"Stop C0000221 Bad Image Checksum in Nom_Module"
"Stop c0000415 Unknown Hard ERROR"
EXPLICATIONS
Incompatibilité logiciel ou défaillance matériel.
Si le message apparait pendant l'installation de Windows, mettre les réglages du bios au minimum.
Ntfs.sys - Page fault_in_nonpaged_area = Dans le BIOS, désactiver les options de mémoire. Si le problème persiste, changer le processeur.
Pilote de périphérique incompatible avec votre version de Windows
Mettre à jour le BIOS de la Carte Mère
Périphérique et logiciel associé incompatible avec votre version de Windows.
Redémarrer en "Mode sans echec" et désinstaller le périphérique et le programme associé.
Incompatibilité materiel ou logiciel
Win32k.sys = problème avec un logiciel de prise à controle à distance
ATI.dll = mettre à jour le driver de la carte graphique
videoprt.sys = "mode sans echec" puis revenir a la version précédente de la carte graphique
Indication de mauvais cablage SCSI ou IDE.
Réinstaller le driver RAID de votre Carte Mère.
Redémarrer plusieurs fois votre Ordinateur.
Une fois que vous avez accéder au bureau de Windows, procédé à la désinstallation des derniers programmes installés.
Problème matériel venant de : Barrette mémoire ou HDD ou Carte Mère, etc...
Pilote de périphérique défaillant ou mal installé.
Réinstaller le Pilote.
Problème physique des barrèttes mémoires.
Procédez à une vérification des barettes mémoires
Erreur STOP dût à un programme résident (antivirus, firewall, etc...)
Peux souvent venir des barrèttes mémoires ou du système de refroidissement du GPU.
Aller sur http://www.microsoft.com" onclick="window.open(this.href);return false; est télécharger le correctif pour l'erreur Stop 0x00000005.
Donnée nécessaire ne se trouvent pas en mémoire.
Ce problème peux venir des Barrèttes mémoires, soit d'un programme incompatible ou alors d'un CPU défectueux ou mal ventilé.
Mettre à jour votre version de Windows, vérifier les pilotes de vos périphériques dans le "Gestionnaire de périphériques" et mettez à jours ceux qui sont en conflit et/ou vérifiez vos Services Windows qui se lancent aux démarrage.
Problème venant du fichier "NTFS.SYS".
Logiciel incompatible avec votre version de Windows.
Désactiver le logiciel (souvent Norton ou Symantec ...) puis refaite une mise à jour de Windows.
Problème venant des Barrètes Mémoire.
Efectuez un test de fonctionnement des Barrèttes Mémoires.
Des données paginées ne sont pas trouvées dans le fichier d'échange.
0xC000009C : Secteur déféctueux sur le HDD
0xC000016A : Secteurs déféctuex sur le HDD
0xC000009D : Problème de connections au HDD (possible souci SCSI ou Carte Mère)
0xC0000185 : Problème de connections au HDD (possible souci SCSI ou Carte Mère)
Utilisez la commande "CHKDSK /f /r"
Erreur suivant une mise à jour du BIOS.
Le HAL (Couche d'Abstraction Matériel) ne correspond plus à celui installé sur votre système.
Faire une réinstallation complète du système.
Page non trouvé dans la mémoire virtuelle.
Problème matériel sur la mémoire vive installé sur votre ordinateur.
Impossibilité au système d'accèder au MBR
Utiliser la console de récupération puis lancer la commande "fixboot" puis redémmarrer l'ordinateur.
Problème arrivant quand vous éteignez l'ordinateur : installer le dernier pilote de votre souris & clavier.
Problème arrivant au démarrage : Désactiver le chargement automatique du logiciel en mémoire.
Périphérique défectueux.
Effectuez une mise à jour du BIOS, Barrètte mémoire endommagés, Service ou Pilote incompatible, programmetiers incompatible (Win32k.sys)
Problème matériel : CPU overcloaké ou problème Carte Mère.
Plusieurs possibilités de problèmes :
Stop 0x1000008E In EMUPIA2K.SYS "KERNEL_MODE_EXCEPTION_NOT_HANDLED_M" : pilote de périphérique non compatible
STOP 0x0000008E (0x00000005,adresse,adresse,adresse) win32k.sys address BF873A32 base at BF800000, datestamp 3d6de5e5" : incompatibilité entre CPU et Carte Mère, effectuez une mise à jour du BIOS.
STOP : 0x0000008E Win 32k.sys Contenu du rapport d’erreurs : c:\windows\Minidump\Mini070403-01.dmp" - c:\DOCUME~1\frab\LOCALS~1\Temp\WER1.tmp.dir.00\sysdata.xml" : Mettre à jour les pilotes Carte Graphique & Carte Son (pilote générique qui cause cette erreur)
Un problème a été détecté et Windows a été arrêté afin de prévenir tout dommage sur votre ordinateur" " PFN-LIST-CORRUPT Informations techniques :
Stop : 0x00008E (0XC0000005 , 0xXXXXXXX , 0xXXXXXXX , 0x00000000)" - "Win32k.sys - adress BFXXXXXX Base at BF800000 DateStamp XXXXXXXX Début du vidage de la mémoire physique . Vidage de la mémoire physique vers le disque" : Tester et/ou changer les Barrèttes Mémoires.
"Stop: 0x0000009C MACHINE_CHECK_EXCEPTION"
Problème matériel serieux.
VentiRad du CPU défecteux ou insuffisant.
Erreur survenant lors d'une mise en veille prolongé.
Périphérique ou composant de votre ordinateur n'est pas compatible avec la norme ACPI
Localisez la défaillance et effectuez une mise à jour de la cause.
Pilote de périphérique obsolète, Serice ou Firmwire incompatible.
Si le problème se pose lors d'une installation de Windows, cela peut provenir du microprocesseur. À titre de test, "under-clockez" votre processeur. Sinon, débranchez tous les périphériques externes puis dans l'ordre :
Lecteurs de carte > lecteurs de disquette > lecteurs/graveurs > modems > cartes son > etc.
Il peut également arriver que ce message soit provoqué suite à un problème sérieux sur le disque dur. Procédez à une vérification du disque en démarrant à partir de la Console de récupération. Vous serez peut-être dans l'obligation d'effectuer un formatage de bas niveau.
"STOP : 0x000000CE DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS"
Ont peux suspecter un problème materiel.
"STOP : 0x000000CE (0xHEXNUM1, 0xXXXXXXX, 0xXXXXXXX , 0xXXXXXXX) in DXAPI.SYS" : Carte vidéo avec fonctionnalité Tuner TV, mettre le pilote du constructeur à la place du pilote actuel.
Pilote de périphérique ou Serice incompatible.
Mettez à jour Windows.
Kbdclass.sys : Pilote ou gestionnaire de clavier non compatible. Désactiver le pare-feu de connection internet.
USBUHCI.SYS : Effectuez une mise à jour du BIOS.
USBPORT.SYS : Mettez à jour le pilote USB
ATAPI.SYS : Mauvais fonctionnement du CPU, dans le BIOS, activer les réglages par défaut.
Erreur STOP Driver irql not less or equal : Mettez vous en mode sans echec puis désactiver le programme de simulation d'un lecteur virtuel (alcool 120%, daemon tools, etc...)
Problème avec la Carte Graphique.
Mettre à jour le pilote de la Carte Graphique
Accéder à la console de récupération puis utiliser la commande CHKDSK /r /p puis patienter environ 30min. Ensuite, utiliser la commande "fixboot".
"Stop : 0x000000F2 Une tempête d’interruption a causé l’arrêt du système"
Effectuez une mise à jour des pilotes de vos périphériques
Problème materiel sur le HDD.
Vérifier le cablage IDE et/ou Cluster Défecteux. Effectuez un test de surface, si le problème persiste, effectuez une réinstallation du système.
"Stop 0xC0000135"
Problème de chargement de la ruche du registre.
Effectuez une réparation du registre de Windows.
"Stop 0xC0000218"
Problème du registre.
Accéder au menu F8 lors du démarrage de Windows et choissisez la derniere bonne configuration connue.
Si le problème persiste utiliser la commande CHKDSK /r et si le problème persiste toujours effectuez une réparation complète du système.
Problème d'autorisation du compte Système, il n'a plus les autorisation pour accéder à lui-même.
Réinstaller l'O.S.
"Stop: C000021a (erreur système irrécupérable) - Le processus système manager initialization s'est terminé de façon innatendue avec l'état 0xC000026C ( 0x00000000 0x00000000) - Le système a été arrêté"
Redémmarez votre Ordinateur avec un seul HDD sur une nappe IDE.
Pilote innaproprié au matériel
Revenir à la version précédente du pilote ou le désinstaller.
"STOP: C0000221 Bad Image Checksum in Nom_Module"
Problème sur les Barrètte Mémoire.
Pilote de périphérique incompatible avec votre version de Windows.
Passez en mode sans echec puis executez la commande devmgmt.msc. Selectionner ensuite votre Carte Graphique et désactiver là. Ensuite redémarrer normalement votre Ordinateur.
gibe
- Membre VIP +
- A remercié : 20 fois
- A été remercié : 37 fois
Re: récapitulatif des erreurs Windows (Blue screen)
Toujours utile ça !
Parfois je me dis que les gens vont se rendre compte de l'arnaque de la mondialisation, du tout électrique, de la cancel culture et qu'ils vont faire la révolution. Puis je réalise que les gens regardent Hanouna, Plus belle la vie, etc.-
Takeitez
- Visiteur
- Bobby2dallas
- Membre officiel
- A remercié : 1 fois
- A été remercié : 2 fois
Pour l'ecran bleu sous seven, cette mise à jour de stabilité, en est une cause, C'est la KB977074 ....
- Prof
- Fondateur
- A remercié : 4 fois
- A été remercié : 14 fois
:rufll: :rufll: :rufll: :rufll: :rufll: :rufll:Takeitez a écrit :C'est celle-là ma préférée
- Chewbacca
- A remercié : 2 fois
- A été remercié : 4 fois
mdr
:rufll: :rufll:
