hebergeur image perso (fotoo hosting)
AigletoN
Message par AigletoN »
http://dev.kd2.org/fotoo/Fotoo+Hosting a écrit : Fotoo Hosting
Fotoo Hosting is a script aimed to be used as a pictures hosting web-service, like imageshack and others.
Features
Lightweight, fast
Accepts JPEG, PNG, SVG, XCF and GIF (even animated GIF files and transparent PNGs)
Preview before upload
Picture resize before upload for fast upload
Fast static image view
Can upload multiples pictures at a time (albums)
Small thumb created for each picture
Can associate a name to each picture
List pictures hosted
Can make a picture private (won't appear in list)
Easy delete of pictures
Short URL for images, for use with twitter-like websites
Easy integration of pictures in forums and blogs, using either BBcode or HTML
Fast resize using the best engine available (from either IMlib, Imagick or GD)
Configuration can be easily changed
Short unique URLs
Intelligent image resize for GIF and PNG files (if created thumb is too big (>50KB) then the thumb will be made in JPEG to keep small image size)
Demo: http://i.kd2.org/" onclick="window.open(this.href);return false;
Install guide
Just download the hosting.php.txt file and rename it to index.php, place it in an empty directory and browse to this directory.
You will need php5-sqlite and php5-imagick (or php-imlib or php5-gd) to make this work.
un "petit" script qui permet d'auto-heberger vos images sur votre propre serveur.
LinuxFR a écrit :découvert sur linuxfr
Vous connaissez peut‐être ImageShack, imgur, TinyPic et bien d’autres encore. Tous ces services ont en commun la possibilité d’envoyer une ou plusieurs images rapidement pour les rendre disponibles en ligne, par exemple dans un forum, ou pour partager un album de photos de vacances, etc. Contrairement à Flickr ou Picasa (et Piwigo, zenphoto et autres équivalents libres), leur but n’est pas d’archiver, classer et trier ses photos, mais simplement de partager rapidement du contenu avec n’importe qui.
Eh bien, Fotoo Hosting, tout comme l’excellent Jyraphe, est une application PHP permettant de faire la même chose que ces imgur et autres TinyPic, sur son propre serveur, sans rien avoir à configurer. Il suffit de copier un seul fichier, et hop !
Fotoo Hosting permet d’envoyer des fichiers seuls (JPEG, PNG, GIF, GIF animé, et XCF et SVG, si ImageMagick est installé) et des albums photos constitués de plusieurs fichiers JPEG. Les grandes images sont redimensionnées avant envoi (en JavaScript) pour soulager votre bande passante, ainsi que le processeur de votre serveur. Il est ensuite possible de partager ces photos très simplement avec un lien court. Les photos peuvent être publiques ou privées (elles n’apparaissent alors pas dans la liste des images hébergées).
Fotoo Hosting est un logiciel libre distribué sous licence AGPL v3.
chrisnad
Re: hebergeur image perso (fotoo hosting)
Message par chrisnad »
merci du partage aigleton :clap: pas mal :)
Fondateur
Fondateur
A remercié : 4 fois
A été remercié : 14 fois
Oki à tester, merci pour le partage :)
Lataupes
Message par Lataupes »
Merci pour le partage.
A plus.
