Re: Windows 11 v21h2 4in1 Fr x64 (11 Janv. 2022)
Posté : jeu. 13 janv. 2022 10:38
Je sais
Il est dedans
Forum de Partage & d'Entraide Informatique
https://www.team-aaz.com/forum/
Je sais
changelog:Georges a écrit : jeu. 13 janv. 2022 22:21 Bonjour,
Yes, le Mas 1.5 est bien dedansmais le Mas 1.4 fonctionne aussi. Quelle est la différence? J'ai bon éditer et lire le code source mais à rien y comprendre..
Merci pour le super taf et cette nouvelle version.![]()
Code : Tout sélectionner
MAS 1.5
# All
- Support added for Windows build 22483 and later (No wmic.exe issue)
- Support added for ARM64 architecture in all the scripts
- Made sure script run fine where path variables are misconfigured in system
- Made sure script run fine from UNC path
- Improved text coloring method
- Script would show an error if ran directly from archive files
- Scripts would make sure to start from the system's main architecture process
- All read me files are shifted to online for better update
- New discord channel https://discord.gg/gjJEfq7ux8 and new main homepage https://windowsaddict.ml/ added
- Various cosmetic improvements and bug fixes
# HWID / KMS38
- HWID Support added for CloudEdition/N, IoTEnterpriseS editions. (IoTEnterpriseS key will be used to activate EnterpriseS 2021)
- KMS38 support added for all new Windows 10-11 and Server's, KMS capable edition's including core and acor editions
- HWID with Lockbox ticket option is added
x86-x64 Lockbox slc.dll is created by @mspaintmsi, @qxkqf ported it to ARM64 slc.dll
- KMS38 Protection and KMS38 uninstall option is added
- Ticket generation option is added
- Improved key detection logic, now it can support custom build editions
- Fixed issues where in certain languages OS's, script would show incorrect status of services
- Improved script options if required key is not found in script
- Improved script options if an edition is not supporting HWID currently but may support in future
# Online KMS
- All related scripts are merged in one in separate files version, with onscreen choice options
- KMS server selection process is improved to make it fail-proof, server numbers are increased to 16
- Improved error handling and display messages
- From now on, KMS server IP address will be used for activation instead of hostname to avoid detection by AV's and MS
- While using manual mode (no renewal task), a non-existent IP 0.0.0.0 will be left in registry to avoid Office non genuine banner issue
- For renewal task, a separate small script will be used to only renew activation, instead of running full script, every week
- Base script is updated to use @abbodi1406's latest KMS_VL_ALL-45u (09-Jan-2022)
Major changes-
Support added for Windows 10 ARM64, Office 2021, all new Windows and Server editions
VBS method will be used for WMI in Windows build 22483 and later
Enhanced detection for Office C2R vNext subscriptions
Check Activation Status [wmi] will show vNext subscriptions status using vNextDiag.ps1 (require Powershell / WMF 4 or later on Windows 7)
Various fixes for Office activation
# Verify_Files-Clear_Zone.Identifier
- This new script is added in root folder to verify files with hashes and to remove Zone.Identifier from files (to prevent SmartScreen warnings)
# Activation Troubleshoot
- This new script is added in Extras section to deal with activation issues. Various options are added with proper onscreen info and warning's.
# Change_W10_11_Edition
- Now it can change the Windows editions from Core to Non core too with proper error handling. Works on Windows build 10240 and later
Après 5 mois , pourquoi tu l'a pas testé encoreilopan a écrit : mar. 15 févr. 2022 15:26 bonjour, vous en pensez quoi du Windows 11 j'aimerai bien le tester
