[Résolu] Il est de retour ... le Bluescreen ! Le sujet est résolu
Re: Il est de retour ... le Bluescreen !
j'ai installé le dernier driver j'attends un bluescreen ou freeze et jte tiens au courant x)
voilà j'ai enfin eu mon Bluescreen x)
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 12/03/2013 18:10:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031213-16816-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x14C2B0)
Bugcheck code: 0x116 (0xFFFFFA800AC33010, 0xFFFFF8800F18E2B0, 0x0, 0xC)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 307.83
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 307.83
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 307.83 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8800F18E2B0)
On Fri 08/03/2013 20:24:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-14835-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x14C19C)
Bugcheck code: 0x116 (0xFFFFFA80098A7010, 0xFFFFF8800F15319C, 0x0, 0x2)
On Fri 08/03/2013 19:54:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-19812-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xAEAA08)
Bugcheck code: 0x116 (0xFFFFFA8009939010, 0xFFFFF8800FBD2A08, 0xFFFFFFFFC000009A, 0x4)
On Tue 05/03/2013 11:25:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030513-12776-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x14BA88)
Bugcheck code: 0x116 (0xFFFFFA800871C010, 0xFFFFF8800F1ADA88, 0x0, 0xC)
On Mon 25/02/2013 20:48:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022513-13634-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80070BF4E0, 0xFFFFF8800F22419C, 0x0, 0xD)
On Sun 24/02/2013 18:01:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022413-12355-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80086574E0, 0xFFFFF8800F20F19C, 0x0, 0xD)
On Mon 18/02/2013 20:25:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021813-12370-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x119CF8)
Bugcheck code: 0x116 (0xFFFFFA800AC184E0, 0xFFFFF8800F11CCF8, 0x0, 0x2)
Conclusion
8 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Crash Dump Analysis
Conclusion
- A remercié : 43 fois
- A été remercié : 171 fois
J'ai trouvé ça :
Plantage de "nvlddmkm.sys" : la solution
Symptôme de ce plantage
Démarche à suivre - Première partie
Démarche à suivre - Deuxième partie
Démarche à suivre - Troisième partie
A lire aussi: Nvlddmkm.sys
Des Scintillement de l'écran (petits clignotements)
Un écran qui « gèle » (image fixe)
Un écran qui devient totalement noir et un retour sous Windows
En effet il arrive parfois que l'on tombe sur des pseudos-solutions (incomplètes, mal expliquées) ou sur des solutions trop compliquées pour la plupart d'entre vous.
Je vais donc vous exposer ma solution en essayant d'être le plus clair possible.
Rendez vous dans le dossier NVIDIA => C:\NVIDIA
Rechercher un fichier nommé « nvlddmkm.sy_ » => C:\NVIDIA\DisplayDriver « Numéro de la version du pilote (exemple : 186.81) »InternationalDisplaynvlddmkm.sy_
N.B : Il se peut bien sur que le chemin d'accès diffère selon chaque ordinateur.
copier le fichier à la racine de C: => C:\nvlddmkm.sy_
Rendez vous dans le dossier système ou sont stockés les drivers => C:\Windows\System32\drivers
Une fois dans ce dossier, rechercher le fichier « nvlddmkm.sys » défectueux et le renommer en « nvlddmkm.sys.old »
Ouvrir l'invité de commande MS-DOS => Touche Windows + R > taper « cmd »
Une fois l'invité de commande ouvert, taper les commandes suivantes :
1) « cd » puis taper entrer (pour vous placer à la racine du disque dur => C:)
2) « expand.exe nvlddmkm.sy_ nvlddmkm.sys » puis taper entrer
"Cette dernière commande vous permet de décompresser le fichier « nvlddmkm.sy_ » que vous aviez placé à la racine de C: et de le transformer pour créer le nouveau « nvlddmkm.sys »"
Aller chercher ce dernier => C:\nvlddmkm.sys
Et replacer le dans le dossier => C:\Windows\System32\drivers
Il ne vous reste plus qu'a redémarrer.
A voir
A voir
J'ai aussi trouvé ça :
J'ai récemment connu une BOSD (Blue Screen of Death) sur mon ordinateur portable fonctionnant sous Windows Vista Ultimate. Le vidage sur incident était énigmatique, comme d'habitude, mais voici ce qu'il a dit.
0x00000116 (0x8811A008, 0x8E414E80, 0x00000000, 0x00000002)
nvlddmkm.sys - adresse 8D00A680 base à 8D0020000, horodatage * D00A680
Apparemment, ce fichier nvlddmkm.sys est un énorme problème avec Vista et Windows 7 et provoque le BSOD quand il s'agit d'une version plus ancienne que ce que Vista ou Windows 7 pense qu'il devrait être. Pour savoir si vous avez ce problème pour vous procédez comme suit.
1. Cliquez sur Démarrer
2. Cliquez sur Exécuter (ou dans la boîte blanche qui dit Démarrer la recherche)
3. Type C: \ windows \ system32 \ drivers et appuyez sur Entrée
4. Trouver le fichier nvlddmkm.sys
5. Faites un clic droit sur le fichier et choisissez Propriétés
6. Allez à l'onglet détails, consultez la version
7. Il est probablement 7.15.11.5669 ou quelque chose proche de cela.
Il ya donc toutes sortes de messages sur la façon dont vous devez modifier le fichier nvlddmkm.sys et faire toutes sortes de code ligne de commande pour le faire fonctionner. Je ne pense pas que c'est le cas pour environ 80% de ces BSOD. Donc, je vais commencer par la méthode la plus simple pour résoudre ce problème et nous allons travailler notre chemin vers les correctifs les plus complexes (si les plus faciles ne fonctionnent pas).
Alors d'abord, je vous suggère de mettre à jour le pilote via site Web de NVIDIA , ce sera très probablement résoudre votre problème, mais je vous suggère de le faire dans un certain ordre des étapes. Alors d'abord aller sur le site de NVIDIA que j'ai posté ci-dessus et il ya deux options, choisir manuellement votre carte vidéo, le type série, type de produit, etc .. et beaucoup d'utilisateurs de base ne savent pas comment trouver cette information. Donc, je suggère d'utiliser l'option NVIDIA automatique, il fonctionne très bien je l'ai utilisé sur mon PC comme un test! L'option automatique fonctionne une installation rapide et trouver le pilote dont vous avez besoin pour votre carte vidéo. Il vous amène à une page de téléchargement où vous souhaitez télécharger le pilote.
Une fois le logiciel téléchargé, vous aurez envie d'aller de l'avant et installer le paquet, en utilisant toutes les valeurs par défaut conviennent. Une fois installé, le système va probablement demander à être redémarré, allez-y et redémarrez. Connectez-vous revenir sur votre système, j'espère qu'il n'y a pas de BSOD et juste pour une double vérification, vous pouvez aller consulter le fichier et assurez-vous que c'est une version plus récente 8.17.11.xxxx plus probable ou quelque chose de similaire. Testez votre PC sur et si il ya plus aucun BSOD vous avez terminé, sinon continuer.
Si le pilote mis à jour ne fonctionne pas pour vous et vous obtenez toujours le BSOD puis, il ya quelques options que vous pouvez essayer. Une autre solution assez simple consiste à copier un nvlddmkm.sys bonnes mises à jour sur l'ordinateur avec les problèmes. Pour que cela fonctionne bien, vous devez avoir un second ordinateur avec Vista ou Windows 7 avec une carte vidéo NVIDIA (pas beaucoup de gens ont ça). Si vous avez un PC supplémentaire avec une bonne carte vidéo NVIDIA travaille puis procédez comme suit.
7. Si la version est 8.11.17.xxxx ou quoi que ce soit plus récente que cela pourrait fonctionner 7.15.11.5669
8. Fermez la page de propriétés
9. Faites un clic droit sur le fichier et choisissez Copier
10. Trouvez un emplacement de stockage en réseau soit ou clé USB et enregistrez le fichier
11. Allez maintenant à votre ordinateur avec la question BSOD et accédez au dossier C: \ windows \ system32 \ drivers
12. Faites un clic droit sur les nvlddmkm.sys et choisissez Renommer
13. Type d'. Vieux à l'extrémité (fichier devrait ressembler à ceci nvlddmkm.sys.old)
14. Maintenant, copiez et collez les nvlddmkm.sys au large de la clé USB \ CD \ DVD dans ce dossier
15. Redémarrage et test
Si votre ordinateur ne possède pas plus de problèmes BSOD alors vous avez réussi fixé votre problème. J'ai entendu dire que ce correctif provoque parfois des erreurs avec Internet Explorer et les contrôles activeX, mais je l'ai fait sur mon PC de test et j'ai vu aucun problème, mais je voulais mettre en garde que cela pourrait avoir des effets néfastes.
Je regarderai ce soir sur mon portable quelle version j'ai de ce fichier et éventuellement te le passer (la j'ai les petits enfants, impossible de faire quoi que ce soit ! lol)
alors la premiere solution 'jai un problème lors de l'invite de commande à l'étape "expand.exe..." bas quand je procede à l'étape et que je fais entrer j'ai ce message dans l'invite de commande "impossible d'ouvrir le fichier nvlddmkm.sy_"
Je pense qu'il faut ouvrir l'invite de commande en tant que administrateur
ha ok mais c'est normal que maintenant ma résolution de mon écran soit déreglé ? ^^" , la résolution n'est plus adapté à mon écran ><
si tu n'as pas pu exécuter la manip, je ne vois pas pourquoi la résolution s'est déréglée
jpense c 'est parce-que j'ai touché aux fichiers des drivers et normalement c'est sensé remplacé le fichier désiré par un autre sauf que moi ça ne l'a pas remplacé donc jpense que c'est ça la raison mais j'ai réinstallé les drivers et la résolution est redevenu normal, sinon me conseil tu de changer de carte graphique ?
