slt tt le monde
voila mon probleme
je veux rajouter de la ram pour mon pc mais je sais pas quoi ajouter comme ram
si qlq un peut m'aider ...merci
je vous presente mon pc
ocessors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Athlon 64 3800+
Codename Orleans
Specification AMD Athlon(tm) 64 Processor 3800+
Package Socket AM2 (940)
CPUID F.F.3
Extended CPUID F.5F
Brand ID 4
Core Stepping
Technology 90 nm
Core Speed 2411.0 MHz (12.0 x 200.9 MHz)
HT Link speed 1004.6 MHz
Stock frequency 2400 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 12.0x
max VID 1.400 V
Features XD, VT
K8 Thermal sensor yes
K8 Revision ID 5.3
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002001h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00050FF3 0x00000800 0x00002001 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00050FF3 0x00000917 0x0000001D 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x72502034 0x7365636F 0x20726F73 0x30303833
0x80000004 0x0000002B 0x00000000 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 I 64 KB 1 threads
Cache descriptor Level 1 D 64 KB 1 threads
Cache descriptor Level 2 U 512 KB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000053
MSR 0xC0010015 edx = 0x00000000 eax = 0x02000001
MSR 0xC0010042 edx = 0x31061208 eax = 0x06100210
MSR 0xC0010041 edx = 0x00000001 eax = 0x00000810
Chipset
Northbridge NVIDIA MCP61 rev. A3
Southbridge NVIDIA MCP61 rev. A2
Memory Type DDR2
Memory Size 1024 MBytes
Channels Single
Memory Frequency 301.4 MHz (CPU/8)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
Command Rate 1T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (0000000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number T100UD12804-667A
Manufacturing date Week 28/Year 08
Attributes
Number of banks 1
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 333
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 15
TRC 12 16 20
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 08 0E 0B 60 40 00 05 30 45 00 82 08 00 00
10 0C 04 38 01 02 00 07 3D 50 50 60 3C 1E 3C 2D 01
20 20 27 10 17 3C 1E 1E 00 00 3C 4B 80 11 28 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 D7
40 00 00 00 00 00 00 00 00 00 54 31 30 30 55 44 31
50 32 38 30 34 2D 36 36 37 41 00 00 00 00 08 28 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 03 00 03 00 00 00 00 31 34 30 30 39 37 30 37 30
90 39 30 30 33 30 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model NF-M2PV (0x1E6 - 0x5A7E56)
LPCIO
Vendor ITE
Vendor ID 0x90
Chip ID 0x8726
Revision ID 0x3
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 26 03 11 00 41 90 01 41 28 01 00 40 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.34 Volts [0x54] (CPU VCORE)
Voltage sensor 1 2.50 Volts [0x9C] (VIN1)
Voltage sensor 2 1.76 Volts [0x6E] (+3.3V)
Voltage sensor 3 5.59 Volts [0xD0] (+5V)
Voltage sensor 4 12.03 Volts [0xBC] (+12V)
Voltage sensor 5 -4.61 Volts [0x48] (-12V)
Voltage sensor 6 -11.65 Volts [0xB6] (-5V)
Voltage sensor 7 5.08 Volts [0xBD] (+5V VCCH)
Voltage sensor 8 3.10 Volts [0xC2] (VBAT)
Temperature sensor 0 17°C (62°F) [0x11] (TMPIN0)
Temperature sensor 1 34°C (93°F) [0x22] (TMPIN1)
Temperature sensor 2 22°C (71°F) [0x16] (TMPIN2)
Fan sensor 0 2163 RPM [0x138] (FANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
00 13 10 FF 00 FF FF 00 00 00 80 01 09 07 38 FF 00
10 FF FF FF 30 D3 7F 7F 40 01 FF 00 EF FF FF FF FF
20 54 9C 6E D0 BC 48 B6 BD C2 10 22 16 14 D1 D1 D1
30 FF FF FF FF FF FF FF FF FF FF 32 76 0A 37 18 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 AB 22 FF FF FF FF
50 FF 31 7F 7F 7F 50 E9 5D 90 5D 3D 12 84 F8 08 88
60 7F 7F 7F 00 00 3F FF FF 7F 7F 7F 00 00 3F FF FF
70 7F 7F 7F 00 00 3F FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 FF FF FF FF 00 00 FF CA 02 00 99 99
90 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PCI Device List
RAM Memory Controller
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0xFF
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset 44h
Revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
Offset DCh
Interface type MSI Mapping
Dump
00 DE 10 EA 03 06 00 B0 00 A1 00 00 05 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 2B 1C
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 7B 14 2B 1C 08 DC 20 02 20 00 11 11 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0D 03 00 00 00 7F 00 00 00
90 78 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
E0 00 00 E0 FE 00 00 00 00 07 00 00 00 20 10 00 00
F0 F0 FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E0
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 2 (port) 0x00001D00
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 E0 03 0F 00 A0 00 A2 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 01 1D 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 7B 14 2B 1C 00 00 FF FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 05 0F 00 FC FF
70 10 00 FF FF C5 80 00 00 00 20 05 19 00 00 00 00
80 09 80 00 11 0D D2 80 00 C0 00 40 01 FF 00 00 00
90 FF 7F 00 00 00 00 00 00 21 65 08 74 B9 0C 00 D0
A0 01 00 10 C0 00 00 00 00 00 00 00 00 00 00 00 00
B0 90 02 EF 02 00 08 5F 08 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 50 41 00 FE FD 01 00 B0
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03EB
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000FC00
Address 4 (port) 0x00001C00
Address 5 (port) 0x0000F400
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x05
Int. Pin 0x01
Capabilities
Power Management Capability
Offset 44h
Version 1.1
Dump
00 DE 10 EB 03 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 1C 00 00 01 F4 00 00 00 00 00 00 7B 14 2B 1C
30 00 00 00 00 44 00 00 00 00 00 00 00 05 01 00 00
40 7B 14 2B 1C 01 00 02 C0 00 00 00 00 00 00 00 00
60 01 10 00 00 01 14 00 00 01 18 00 00 00 00 00 00
70 00 00 00 00 00 00 C8 FE 00 00 FE FE 01 20 00 00
80 00 10 FE FE 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 40 00 40 01 10 00 00 00 05 00 00 00 00 00 00 00
E0 88 10 04 00 04 40 00 07 80 12 00 20 41 44 44 11
F0 02 FF 1E BF 01 00 00 80 10 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03F5
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 F5 03 00 04 A0 00 A2 00 00 05 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 10 02 80 10 10 00 10 10
50 10 10 10 10 00 00 00 00 00 00 00 00 10 42 00 00
60 0B 00 00 00 C0 1C 52 06 21 00 10 0A 00 00 63 00
70 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 40 00 00 00 00 00 A0 18 00 00
90 00 00 00 00 00 00 00 12 20 81 04 00 00 00 00 00
A0 00 14 00 06 00 00 00 00 00 00 00 00 01 00 00 00
B0 00 00 00 00 42 80 30 04 00 00 00 00 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F1
Revision ID 0xA3
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE02F000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 F1 03 07 00 B0 00 A3 10 03 0C 00 00 80 00
10 00 F0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
40 7B 14 2B 1C 01 00 02 FE 00 00 00 00 00 00 00 00
50 04 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F2
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE02E000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x14
Int. Pin 0x02
Capabilities
Debug Port Capability
Offset 44h
Offset 80h
Version 1.1
Dump
00 DE 10 F2 03 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 E0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
40 7B 14 2B 1C 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 C3 13 0F 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 04 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B0 33 00 11 22 44 00 00 00 FF 03 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F3
Revision ID 0xA1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Subsystem Vendor Capability
Offset B8h
Subsystem ID 0xCB84
Sub. Vendor ID 0x10DE
Offset 8Ch
Dump
00 DE 10 F3 03 07 00 B0 00 A1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 FF 00 04 02
40 00 00 73 07 01 00 02 00 07 00 00 00 00 00 48 00
50 00 00 00 00 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 06 00 00 FC FF 0E 00 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 DE 10 84 CB
C0 DE 10 84 CB 03 00 00 00 00 00 00 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F0
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE024000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Message Signalled Interrupts Capability
Offset 50h
Offset 6Ch
Dump
00 DE 10 F0 03 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 40 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 02 02 05
40 7B 14 2B 1C 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 02 A8
F0 00 00 00 00 00 00 00 47 00 29 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EC
Revision ID 0xA2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000F000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 EC 03 05 00 B0 00 A2 8A 01 01 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 7B 14 2B 1C
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 7B 14 2B 1C 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 20 20 6A 00 99 20
60 00 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
Bridge device
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EF
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE02D000
Address 1 (port) 0x0000EC00
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset 50h
Offset 6Ch
Dump
00 DE 10 EF 03 07 00 B0 00 A2 00 80 06 00 00 00 00
10 00 D0 02 FE 01 EC 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 01 14
40 7B 14 2B 1C 01 50 02 FE 00 00 00 00 08 00 00 20
50 05 6C 86 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 FF 00 00 00 08 00 02 A8
F0 00 00 00 00 00 00 00 00 42 01 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009F0
Address 1 (port) 0x00000BF0
Address 2 (port) 0x00000970
Address 3 (port) 0x00000B70
Address 4 (port) 0x0000D800
Address 5 (memory) 0xFE02C000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
00 DE 10 F6 03 07 00 B0 00 A2 85 01 01 00 00 80 00
10 F1 09 00 00 F1 0B 00 00 71 09 00 00 71 0B 00 00
20 01 D8 00 00 00 C0 02 FE 00 00 00 00 7B 14 2B 1C
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
40 7B 14 2B 1C 01 B0 02 00 00 00 00 00 00 00 00 00
50 2F 68 08 00 00 00 00 00 A8 A8 A8 20 6A 00 99 20
60 00 00 00 C7 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
80 00 00 00 40 00 F0 83 32 00 00 08 80 3E FF FF F9
90 00 00 F8 2A 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 0F 00 00 00 00 00 00 00 00 33 31 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 08 00 00 77 00 08 03 00 08 00 00 44 00 08 08 00
E0 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 8 (0x08), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009E0
Address 1 (port) 0x00000BE0
Address 2 (port) 0x00000960
Address 3 (port) 0x00000B60
Address 4 (port) 0x0000C400
Address 5 (memory) 0xFE02B000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x17
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
10 E1 09 00 00 E1 0B 00 00 61 09 00 00 61 0B 00 00
20 01 C4 00 00 00 B0 02 FE 00 00 00 00 7B 14 2B 1C
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 03 01
50 2F 68 08 00 00 00 00 00 A8 A8 A8 A8 AA 00 99 99
60 00 00 00 00 41 0C 00 00 00 0F 06 42 00 00 00 00
80 00 00 00 00 FE FF FD 3F 00 00 F0 3F FE 7F FC 7E
90 00 00 BD 37 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 00 00 00 00 00 00 00 00 00 33 31 00 02
D0 08 00 00 44 00 08 08 00 08 00 00 44 00 08 08 00
PCI to PCI Bridge
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E8
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0000
Offset 48h
Version 1.1
Offset 50h
Offset 60h
PCI Express Capability
Offset 80h
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect no
Link width 16x (max 16x)
Dump
00 DE 10 E8 03 07 00 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 A1 A1 00 00
20 D0 FD D0 FD C1 FD C1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 FF 00 04 00
40 0D 48 00 00 DE 10 00 00 01 50 02 F8 00 00 00 00
50 05 60 82 00 00 00 00 00 00 00 00 00 00 00 00 00
60 08 80 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 30 28 00 00 01 3D 11 00
90 00 00 01 11 80 25 08 00 C0 01 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0000
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
Dump
00 DE 10 E9 03 07 00 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 91 91 00 00
20 B0 FD B0 FD A1 FD A1 FD 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 30 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0000
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 2
Version 1.0
Physical slot #0
Presence detect no
Dump
10 00 00 00 00 00 00 00 00 00 04 04 00 81 81 00 00
20 90 FD 90 FD 81 FD 81 FD 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 30 28 00 00 11 3C 11 02
90 00 00 11 10 00 05 18 00 C0 01 00 00 00 00 00 00
VGA Controller
bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03D0
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFB000000
Address 1 (memory) 0xE0000000
Address 3 (memory) 0xFC000000
Subvendor ID 0x147B
Subsystem ID 0x1C2B
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Offset 50h
Dump
00 DE 10 D0 03 07 00 B0 00 A2 00 00 03 00 00 00 00
10 00 00 00 FB 0C 00 00 E0 00 00 00 00 04 00 00 FC
30 00 00 00 00 48 00 00 00 00 00 00 00 14 01 00 00
40 7B 14 2B 1C 00 00 00 03 01 50 02 00 00 00 00 00
50 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 00 00 00 1C 04 04 00 00 00 00 00 00 00 00 00
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 00 00 70 00 00 00 00 08 00 00 00 00 FF FF FF FF
Host Bridge
bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Revision 1.02
Interface type Host/Secondary
Device number 0
Dump
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 2E 0F 0C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 04 00 07 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 3F 00 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 0A 00 00 00 0B 00 00 00 00 00 00 00 00 00 00
90 03 00 40 00 00 FF EF 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 03 00 F4 00 00 02 FE 00
B0 03 00 F0 00 80 3F F0 00 00 00 00 00 00 00 00 00
C0 13 80 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
50 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 E0 3F 38 00 00 00 00 00
70 00 00 00 00 00 00 00 00 46 00 00 00 00 00 00 00
80 00 06 00 00 00 00 00 00 24 CA 6A FF 20 13 02 08
90 10 00 01 00 6A 00 00 A4 10 00 00 80 00 00 00 00
A0 FB 02 00 5D 00 00 00 00 00 00 00 00 00 00 00 00
B0 12 AD 9F C8 E3 00 00 00 1D FF 61 8A 34 26 08 00
D0 11 04 89 07 0E D0 C5 81 88 10 6E 56 9C 22 05 38
E0 19 0A 80 0F 84 92 C4 D0 0A 08 35 25 DE A3 41 10
Host Bridge
bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Secure Device Capability
Offset F0h
Dump
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF 3B 04 00 40 00 10 02 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 80 7B 0C C0
60 EB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 32 51 21 40 70 50 00 2A 00 08 18 21 00 00
80 00 26 27 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 F7 0E 00 00 40 C8 FF 15 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 60 00 25 26 26 00
E0 00 00 00 00 24 22 00 00 19 07 00 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 F3 0F 05 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 03/14/2008
DMI System Information
manufacturer System Manufacturer
product System Product Name
version System Version
serial System Serial Number
UUID FEFEFEFE-FEFEFEFE-FEFE0018-370A7632
DMI Baseboard
vendor http://www.abit.com.tw" onclick="window.open(this.href);return false;
model NF-M2PV
revision 1.0
serial OEM
DMI System Enclosure
manufacturer System Enclosure Manufacturer
chassis type Desktop
chassis serial Unknow
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 Processor 3800+
clock speed 2412.0 MHz
FSB speed 201.0 MHz
multiplier 12.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation A0
DMI Memory Module
designation A1
size 1024 MBytes (single bank)
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
Resources
Port I/O Space, BA=0x1D00
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0x1C00
Port I/O Space, BA=0xF400
Memory I/O Space, BA=0x00000000FE02F000
Memory I/O Space, BA=0x00000000FE02E000
Memory I/O Space, BA=0x00000000FE024000
Port I/O Space, BA=0xF000
Memory I/O Space, BA=0x00000000FE02D000
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0x9F0
Port I/O Space, BA=0xBF0
Port I/O Space, BA=0x970
Port I/O Space, BA=0xB70
Port I/O Space, BA=0xD800
Memory I/O Space, BA=0x00000000FE02C000
Port I/O Space, BA=0x9E0
Port I/O Space, BA=0xBE0
Port I/O Space, BA=0x960
Port I/O Space, BA=0xB60
Port I/O Space, BA=0xC400
Memory I/O Space, BA=0x00000000FE02B000
Memory I/O Space, BA=0x00000000FB000000
Memory I/O Space, BA=0x00000000E0000000
Memory I/O Space, BA=0x00000000FC000000
Port I/O Space, BA=0x1008, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
j'espere avoir une reponse rapidement .....merci d'avance
ravi d'etre parmis vous.
besoins de votre lumiere ....merci
- Prof
- A remercié : 1 fois
- A été remercié : 22 fois
Re: besoins de votre lumiere ....merci
le passage important c'est :
Et pour info ta CM est une ABIT NF-m2PV
Donc pour moi le souci c'est que tu veux surement garder ta barrette de 1Go déjà présente... or c'est du 333mhz et on n'en trouve quasiment plus en vente, et ce n'est pas bon de tourner avec des barrettes à différentes fréquences !
Donc le mieux est de racheter 2 barrettes neuves compatibles avec ta CM, par exemple :
http://www.pixmania.com/fr/fr/1416941/a ... 33mhz.html
Arpès je n'ai pas cherché la meilleure promo, mais c'est pour te donner une première réponse, d'autres trouveront peut-être autre chose...
Memory type DDR2
Size 1024 MBytes
- A remercié : 66 fois
- A été remercié : 46 fois
http://www.rueducommerce.fr/index/barrette%20ddr2" onclick="window.open(this.href);return false;
http://www.ldlc.com/navigation/cat.html ... 829_1_val=" onclick="window.open(this.href);return false;
DDR2 PC5300
DDR2 PC5300
