bonsoir,
voila après un crash écran bleu j ai perdu le thème d arium...
est il possible de le récupérer ou ceci est il irreversible?
si quelqu un peu me faire une conclusion sur le rapport merci
rapport whocrashed: désolé po réussi a le joindre!
System Information (local)
computer name:PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ AMD586, level: 15
2 logical processors, active mask: 3
RAM: 4294500352 total
VM: 2147352576, free: 1911566336
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
No valid crash dumps have been found on your computer
Conclusion
Crash dumps are enabled but no valid crash dumps have been found. It may be that there are problems which prevent crash dumps from being written out. Check out the following article for possible causes: If crash dumps are not written out.
In case your computer does experience sudden reboots it is likely these are caused by malfunctioning hardware, power failure or a thermal issue. To troubleshoot a thermal issue, check the temperature using your BIOS setup program, check for dust in CPU and motherboard fans and if your computer is portable make sure it's located on a hard surface. Otherwise it's suggested you contact the support department of the manufacturer of your system or test your system with a memory test utility for further investigation.
Check out the following articles for more information: Troubleshooting sudden resets and shut downs.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
[résolu]perte thème arium
- Nash
- A été remercié : 21 fois
Re: perte thème arium
perdu le theme ?? et dans le dossier ressources ya rien ?? bizarre ca lol
• 1 x SSD 500GB PCIe4 M.2 SEA
- Prof
- A remercié : 1 fois
- A été remercié : 22 fois
quoi ? ça existe encore Arium ?
c'est peu etre pas plus mal d'avoir perdu le theme arium ^^
ok ok je sors -------->
merci pour vos réponses!!!
vos désaccords avec matx me regarde en rien!!
j aurai aimer une réponse plus positive de votre part mais rien!!!
c est quoi ça!! "T ECOUTE PAS ET PUIS C EST TOUT!!!" MDR!!!(sahez que la roue tourne les gars!!!)
une petite conclusion sur le rapport whocrashed mais rien !!!
merci pour le positif!!!
bonne journée!!!
bonne journée!!!
- Prof
lol atomik on plaisante un peu mais c'est de bonne guerre
Personnellement je n'ai même pas pris le temps de lire ton rapport de crash car je manque cruellement de temps et je n'avais pas compris que c'était ce qui t’interessait le plus puisque le titre de ton sujet est "perte du thème arium" et non "besoin d'aide sur un rapport de crash"
Enfin je ne vois pas ce que tu veux qu'on te dise sur ton whocrashed puisqu'il est vide...
Mes conseils sont donc :
- restauration
- MAJ drivers
- Nettoyage
Enfin la classique quoi...
Et par curiosité tu l'as provoqué comment ton écran bleu ?
- restauration
- MAJ drivers
- Nettoyage
demande qu'on te file les mssstyle etc qui font le théme arium a quelqu'un qui en use et voilà
