![Image](https://www.ginjfo.com/wp-content/uploads/2021/09/Windows11_Perf-620x330.jpg)
Windows 11 build 22000.184 ne propose aucune nouvelle fonctionnalité. Microsoft se concentre sur la correction de problème. Par exemple nous avons un correctif visant la traduction de l’OS. Une défaillance est à l’origine pour certaines langues d’une traduction partielle de l’interface du système d’exploitation. Le souci de la disparition de « en savoir plus » dans l’expérience OOBE dans les versions non anglaise de Windows 11 est corrigé.
Il y a encore de nombreux problèmes connus et sans solution. Vous trouvez tous les détails ci dessous.
Windows 11, rendez-vous le 5 octobre prochain.Windows 11 build 22000.184 - Note de version
Fixes
[General]
Fixed an issue where the new learn more info in OOBE about Windows Hello wasn’t translated for non-English languages.
Fixed an issue where a small set of languages were missing translations across the UI in Windows 11.
Known issues
[General]
We’re investigating reports from Insiders in the Beta Channel where after upgrading to Windows 11, they are not seeing the new Taskbar and the Start menu doesn’t work. To workaround this if you are impacted, please try going to Windows Update > Update history, uninstalling the latest cumulative update for Windows, and the reinstall it by checking for updates.
We’re working on a fix for an issue that is causing some Surface Pro X’s to bugcheck with a WHEA_UNCORRECTABLE_ERROR.
[Start]
In some cases, you might be unable to enter text when using Search from Start or the Taskbar. If you experience the issue, press WIN + R on the keyboard to launch the Run dialog box, then close it.
System and Windows Terminal is missing when right-clicking on the Start button (WIN + X).
[Taskbar]
The Taskbar will sometimes flicker when switching input methods.
[Search]
After clicking the Search icon on the Taskbar, the Search panel may not open. If this occurs, restart the “Windows Explorer” process, and open the search panel again.
Search panel might appear as black and not display any content below the search box.
[Widgets]
The widgets board may appear empty. To work around the issue, you can sign out and then sign back in again.
Widgets may be displayed in the wrong size on external monitors. If you encounter this, you can launch the widgets via touch or WIN + W shortcut on your actual PC display first and then launch on your secondary monitors.
[Microsoft Store]
We continue to work to improve search relevance in the Store.
[Windows Sandbox]
Within Windows Sandbox, the language input switcher does not launch after clicking the switcher icon on the Taskbar. As a workaround, users can switch their input language via any of the following hardware keyboard shortcuts: Alt + Shift, Ctrl + Shift, or Win + Space (the third option is available only if Sandbox is full-screened).
Within Windows Sandbox, the IME context menu does not launch after clicking the IME icon in the Taskbar. As workarounds, users can access the functionalities of the IME context menu with either of following methods:
Accessing the IME settings via Settings > Time & language > Language & region > (e.g., Japanese) three dots > Language options > (e.g., Microsoft IME) three dots > Keyboard options.
Optionally, you may also enable the IME toolbar, an alternative UI, to quickly invoke specific IME functions. Continuing from above, navigate to Keyboard options > Appearance > Use IME toolbar.
Using the unique set of hardware keyboard shortcuts associated with each IME-supported language. (See: Japanese IME Shortcuts, Traditional Chinese IME Shortcuts).
Le déploiement de Windows 11 va débuter le 5 octobre prochaine. Timide dans un premier temps un coup d’accélérateur est prévu en début d’année 2022. L’objectif est de proposer la mise à niveau à tous les PC Windows 10 éligibles d’ici le ùmi-2022
A ce sujet Microsoft précise
Les PC non pris en charge n’auront qu’une seule alternative, Windows 10. Sa maintenance est assurée jusqu’en 2025.« La mise à niveau gratuite vers Windows 11 commence le 5 octobre et sera progressive et mesurée en mettant l’accent sur la qualité. Suite aux formidables apprentissages de Windows 10, nous voulons nous assurer que nous vous offrons la meilleure expérience possible. Cela signifie que les nouveaux appareils éligibles se verront proposer la mise à niveau en premier. La mise à niveau sera ensuite déployée au fil du temps sur les appareils du marché en fonction de modèles d’intelligence qui tiennent compte de l’éligibilité du matériel, des mesures de fiabilité, de l’âge de l’appareil et d’autres facteurs ayant un impact sur l’expérience de mise à niveau. (…)
Si vous disposez d’un PC Windows 10 éligible à la mise à niveau, Windows Update vous informera lorsqu’il sera disponible. Vous pouvez également vérifier si Windows 11 est prêt pour votre appareil en allant dans Paramètres > Windows Update et sélectionnez Rechercher les mises à jour. »
