pc qui rame au démarrage
Re: pc qui rame au démarrage
salut palerider et soulfate
@palerider:
Rapport de ZHPFix 2015.4.9.5 par Nicolas Coolman, Update du 18/03/2015
Fichier d'export Registre :
Run by scorebut at 23/04/2015 18:58:49
High Elevated Privileges : OK
Windows 8 Business Edition, 32-bit Service Pack 1 (9600)
Corbeille vidée (00mn 02s)
Dossier Prefetcher vidé
Réparation des raccourcis navigateur
========== Clés du Registre ==========
SUPPRIMÉ: HKCU\Software\eSupport.com
========== Valeurs du Registre ==========
Aucune Valeur Standard Profile: FirewallRaz :
Aucune Valeur Domain Profile: FirewallRaz :
SUPPRIMÉ: FirewallRaz (Domain) : {A9080F4C-BE69-49F6-87CD-FAE444526D27}
SUPPRIMÉ: FirewallRaz (Domain) : {AF4CD98F-A6B6-4B1C-8D65-661A94CE0BDE}
========== Dossiers ==========
Aucun dossiers CLSID Local utilisateur vide
========== Fichiers ==========
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 business portable\aida_diskbench.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 engineer portable\aida_diskbench.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 extreme portable\aida_diskbench.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 business portable\aida_bench32.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 business portable\aida_bench64.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 engineer portable\aida_bench32.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 engineer portable\aida_bench64.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 extreme portable\aida_bench32.dll
SUPPRIMÉ: c:\users\scorebut\downloads\aida64 extreme engineer business portable et installation 5.20.3400 novirus\aida64 extreme portable\aida_bench64.dll
SUPPRIMÉ: c:\users\scorebut\appdata\local\temp\nvidia corporation\nv_cache\4efb409cba728e5c8b8fb59296463130_fce8395f8fd8a82b_15f74c7777689be5_3_0.bin
SUPPRIMÉ: c:\users\scorebut\appdata\local\temp\nvidia corporation\nv_cache\4efb409cba728e5c8b8fb59296463130_fce8395f8fd8a82b_8e912777872ba4e3_2_0.bin
SUPPRIMÉS Temporaires Windows (25) (2 588 906 octets)
SUPPRIMÉS Flash Cookies (0) (0 octets)
========== Restauration Système ==========
Point de restauration du système créé avec succès
========== Récapitulatif ==========
1 : Clés du Registre
4 : Valeurs du Registre
1 : Dossiers
13 : Fichiers
1 : Restauration Système
End of clean in 00mn 06s
========== Chemin de fichier rapport ==========
C:\Users\scorebut\AppData\Roaming\ZHP\ZHPFix[R1].txt - 23/04/2015 18:58:52 [2936]
@palerider:
1 : Dossiers
13 : Fichiers
- A remercié : 42 fois
- A été remercié : 225 fois
https://up2sha.re/file?f=zm9Gx3EEBjI9" onclick="window.open(this.href);return false;
bonne nuit l'ami
bonne nuit l'ami
Apparemment le rapport est clean.
- Si tu as utilisé Malwarebytes vide la quarantaine (dans le cas où il y a quelque chose).
- Vide la quarantaine de ton anti-virus.
- • Télécharge TFC (de OldTimer) sur ton Bureau.
• Ferme tous tes programmes.
• Lance TFC (si tu es sous Windows Vista ou Windows 7, fais le par un clic-droit --> Exécuter en temps qu'administrateur)
• Clique sur le bouton Start pour lancer le nettoyage.
• Lorsqu'il aura terminé, l'outil devrait faire redémarrer ton ordinateur. (pas obligatoire) - Télécharge DelFix (de Xplode ) sur ton bureau.
- Exécute-le
- Coche toutes les cases sauf "Effectuer une sauvegarde du registre"
- Clique sur "Exécuter"
- Patiente...
- Lorsque les procédures seront terminées, l'outil va se fermer et disparaître du bureau
- Un rapport est sauvegardé dans le presse-papier (donc non "visible") : il te suffit de faire un clic droit et "coller" dans ta prochaine réponse pour me poster le rapport
# DelFix v10.9 - Rapport créé le 24/04/2015 à 18:39:20
# Mis à jour le 27/02/2015 par Xplode
# Nom d'utilisateur : scorebut - TOUR-VE
# Système d'exploitation : Windows 8.1 Pro (32 bits)
~ Activation de l'UAC ... OK
~ Suppression des outils de désinfection ...
Supprimé : C:\AdwCleaner
Supprimé : C:\QuickDiag
Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZHP
Supprimé : C:\Program Files\ZHPDiag
Supprimé : C:\PhysicalDisk0_MBR.bin
Supprimé : C:\Users\scorebut\Desktop\AdsFix.exe
Supprimé : C:\Users\scorebut\Desktop\adwcleaner_4.201.exe
Supprimé : C:\Users\scorebut\Desktop\Defogger.exe
Supprimé : C:\Users\scorebut\Desktop\defogger_disable.log
Supprimé : C:\Users\scorebut\Desktop\JavaRa-2.6.zip
Supprimé : C:\Users\scorebut\Desktop\pre_scan-en-live-cd.html
Supprimé : C:\Users\scorebut\Desktop\RKreport_DEL_04152015_133010.log
Supprimé : C:\Users\scorebut\Desktop\SXCU.exe
Supprimé : C:\Users\scorebut\Desktop\TFC.exe
Supprimé : C:\Users\scorebut\Desktop\ZHPCleaner (2).exe
Supprimé : C:\Users\scorebut\Desktop\ZHPCleaner.exe
Supprimé : C:\Users\scorebut\Desktop\ZHPCleaner.txt
Supprimé : C:\Users\scorebut\Desktop\ZHPDiag.lnk
Supprimé : C:\Users\scorebut\Desktop\ZHPDiag.txt
Supprimé : C:\Users\scorebut\Desktop\ZHPDiag2.exe
Supprimé : C:\Users\scorebut\Desktop\ZHPFix.lnk
Supprimé : C:\Users\scorebut\Desktop\ZHPFixReport.txt
Supprimé : C:\Users\scorebut\Desktop\ZHPFix[R1].txt
Supprimé : C:\Users\scorebut\Downloads\adsfix_06.04.2015.2.exe
Supprimé : C:\Users\scorebut\Downloads\adwcleaner_4.112.exe
Supprimé : C:\Users\scorebut\Downloads\adwcleaner_4.200.exe
Supprimé : C:\Users\scorebut\Downloads\JRT.exe
Supprimé : C:\Users\scorebut\Downloads\rkill.exe
Supprimé : C:\Users\scorebut\Downloads\RogueKiller X64 et X86 (V10.5.7 22 mars_2015) Novirus.torrent
Supprimé : C:\Users\scorebut\Downloads\RogueKiller X64 et X86 portable et installation ( V10.5.10 15 Avril_2015 ) Novirus.torrent
Supprimé : C:\Users\scorebut\Downloads\RogueKiller X64 et X86 portable et installation ( V10.5.9 8 Avril_2015 ) Novirus.torrent
Supprimé : C:\Users\scorebut\Downloads\UsbFix_7.915.exe
Supprimé : C:\Users\scorebut\Downloads\UsbFix_7.917.exe
Supprimé : C:\Users\scorebut\Downloads\ZHP (ZebHelpProcess) 2015.3.8.3 Analizeur de rapport ZHPDiag Novirus.torrent
Supprimé : C:\Users\scorebut\Downloads\ZHPCleaner (1).exe
Supprimé : C:\Users\scorebut\Downloads\ZHPcleaner 2015.3.26.140 Novirus.torrent
Supprimé : C:\Users\scorebut\Downloads\ZHPCleaner.exe
Supprimé : C:\Users\scorebut\Downloads\ZHPDiag2 (1).exe
Supprimé : C:\Users\scorebut\Downloads\ZHPDiag2 (2).exe
Supprimé : C:\Users\scorebut\Downloads\ZHPDiag2.exe
Supprimée : HKLM\SOFTWARE\OldTimer Tools
Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ZHPDiag_is1
~ Purge de la restauration système ...
Supprimé : RP #7 [point restauration avant zhpscript | 04/23/2015 16:55:56]
Nouveau point de restauration créé !
~ Réinitialisation des paramètres système ... OK
########## - EOF - ##########
merci
PS: par contre tu m'a pas dis pour installer en dual boot kali linux et windows est ce que je suis obliger de supprimer la partition windows 8.1 et instaler en premier windows 7 ensuite windows 8 et ensuite kali ou peut etre debian?
cordialement.
merci
cordialement.
PS: dans le rapport delfix je vois ça :
Tu l'as téléchargé où ?
Les utilitaires de désinfection c'est sur le site de l'éditeur et pas ailleurs ! Risque de surinfection !
Normalement tu installes Linux en dernier. Demande l'avis d'un spécialiste du dual-boot perso je n'ai rien d'installé dans le genre.PS: par contre tu m'a pas dis pour installer en dual boot kali linux et windows est ce que je suis obliger de supprimer la partition windows 8.1 et instaler en premier windows 7 ensuite windows 8 et ensuite kali ou peut etre debian?
Tu l'as téléchargé où ? sur un tracker priver que tu connais bien
PS: c'est qui le spécialiste du dual boot.?
Je le dis et je le maintient les utilitaires de désinfection c'est sur le site du créateur et pas ailleurs !sur un tracker priver que tu connais bien
Pour les outils de coleman : sur son site, sur zebulon et sur comment ça marche.
